- 5:16 PM
- Feb 29, 2020
- Heart of Dixie.....
Guys, need a dizzy for my 440 project. In searching the many threads I like the GM HEI conversion as I am very familiar with those systems. The 440 a PO had installed in my 73 had replaced the electronic unit with a point type from a 69 440. I have a dizzy from a small block and it seems to bolt in and line up....the only difference I can see is the location of the vacuum advance....can you swap them or need one made for your motor.
I plan to use the ford coil, GM control module and the writers suggusted just getting a refurbished Mopar unit for $50 bucks.....in my net search I haven't found one. All I see is A Team dizzy s that I assume are Chinease knockoffs and some say not very reliable .....what say you....thanks....
