Do I need to balance the crank?
Engine, Trans & Driveline
  1. BeepBeepRR
    BeepBeepRR FBBO Gold Member FBBO Gold Member
    5,613
    7390
    Oct 16, 2016
    Atlanta,Ga
    Local Time:
    10:05 PM
    Couple ounces here, couple there.. whats the difference? Tell ya what go to a ceiling fan and tape a 1/2 inch nut to one blade and fire it up.. See what happens.
    • Like Like x 2
    • 66 Sat
      66 Sat Well-Known Member
      837
      1259
      Apr 26, 2015
      Australia
      Local Time:
      9:05 PM
      If your budget is tight wait a few more weeks and save the money up to get it done. It's cheap insurance. If it all goes back together and it has an imbalance you are stuffed, without a leg to stand on, as the machine shop has advised to have it done. The cost to pull the motor and then strip it all, and then pay to have it balanced will be considerably more (and way more hassle and stress). Do it once, do it right.
    • BSB67
      BSB67 FBBO Gold Member FBBO Gold Member
      1,486
      1190
      Jan 18, 2018
      PA
      Local Time:
      10:05 PM
      The wrist pins will weigh the same. The factory piston is 770 grams. If you're worried about it, put the TRWs on a scale. Unless something has changed in the world of replacement piston, they'll be close enough is my guess.
    • BSB67
      1,486
      1190
      Jan 18, 2018
      PA
      Local Time:
      10:05 PM
      Cut the nut in half, and mount it 1 11/16" from the fan centerline.
      • Like Like x 1
      • HT413
        HT413 Semi Pro Bowler
        5,317
        5329
        Jul 5, 2012
        New Jersey
        Local Time:
        10:05 PM
        Here’s the advice my friend gave me: at 6000 rpm, each piston is changing direction 120 times a second...
        spend the hundred bucks
        • Like Like x 1
        • BSB67
          1,486
          1190
          Jan 18, 2018
          PA
          Local Time:
          10:05 PM
          Have your friend check his math. What else did he tell you?
          The changing direction of the piston has nothing to do with the need for balancing. Balanced or not the the 1000 gram piston/pin will be changing direction.
          • Agree Agree x 1
          • 65-440
            65-440 Well-Known Member
            2,828
            2213
            Dec 2, 2009
            virginia beach, va
            Local Time:
            1:05 AM
            Why risk it, it's not worth it to me. The engines already apart. Seems like a no brainier. How much are they charging you to balance?
          • 67charger383
            67charger383 Well-Known Member
            647
            1126
            Dec 13, 2019
            Maryland
            Local Time:
            10:05 PM
            Thanks to everyone who commented on this thread.
            I will have it balanced.
            • Like Like x 5
            • BSB67
              1,486
              1190
              Jan 18, 2018
              PA
              Local Time:
              10:05 PM
              Sure. Today, I would do it too considering my current situation.
              When I didn't do it, it was because there were a lot of other things competing for the $200, or what ever it cost back then.
              There were probably tens of thousands, if not a hundred thousand motors rebuilt without balancing through the 60's, 70's, 80's and early 90's before we got too smart to do such a thing. Just one more thing in the "you cant do that" bucket despite the fact that it used to be done all the time.
            • Curiousyellow71
              Curiousyellow71 Well-Known Member
              566
              391
              Jun 18, 2019
              Nebraska
              Local Time:
              9:05 PM
              Built many we did not balance. It would probably be fine. But it is cutting a corner...and I am glad to here you are balancing it. When they do the calculations for the bobweights for balancing the crank they use 100% of the rotating weight and 50% recipricating. The piston end accounts for 50% of the bobweight. So let's say your pistons are 50 grams heavier...it amounts to 25 grams on your bobweight. For most street builds it would be hard to tell the difference when your sitting behind the steering wheel. Some of the cheaper forged pistons are pretty heavy compared to the original cast piston...the only way to know is find the weights of both pistons and compare.
              I just wrote out a check to balance 2 mopars yesterday. 150 bucks per engine. Imo really reasonable. But I've paid $400 to have one balanced where Mallory metal had to be added...the new assembly had heavier rods and pistons then stock. Imo...its a common mistake buying rods and pistons. If you purchase lighter rods and pistons...they will have to lighten the crank which involves drilling holes in the counterbalances and is inexpensive. If you skimp and add heavier pistons or rods it's more expensive to balance if they have to add weight instead of drill. Some of the heavy metals are expensive. But...it all depends on how heavy or how light.
            • BSB67
              1,486
              1190
              Jan 18, 2018
              PA
              Local Time:
              10:05 PM
              And I'd be surprised if a TRW/Speed Pro/Sealed Power replacement type piston would be 50 grams different than the factory piston.
              • Agree Agree x 1
              • BSB67
                1,486
                1190
                Jan 18, 2018
                PA
                Local Time:
                10:05 PM
                Actually, It's starting to come back to me. Those weights for the TRW/Sealed Power/Speed Pro pistons used to be published. I think the domed pistons were actually a little heavier, but they took weight out of the pin so that the balance would match the factory piston as well.
              • Curiousyellow71
                566
                391
                Jun 18, 2019
                Nebraska
                Local Time:
                9:05 PM
                Yes... they tapered the inside ends of the wrist pin...and went from like 220g to 180g. Pretty trick set of pins back in the day.
              • dvw
                dvw Well-Known Member
                5,372
                7636
                Feb 16, 2010
                waterford mi
                Local Time:
                10:05 PM
                • Like Like x 1
                • Curiousyellow71
                  566
                  391
                  Jun 18, 2019
                  Nebraska
                  Local Time:
                  9:05 PM
                  I would bet that there are more motors out there with trw/sealed power forged slugs that were not rebalanced then ones that were. That brand has been around forever and balancing used to be relatively uncommon...most machine shops would have to send it off to get the balancing done so balancing became a bragging point if you had it done..Lol. Like it was going to make it have another 100hp or something . Which I always thought was humorous and a sign someone didnt know anything....and they usually had a chevy. Lol.
                  Balancing has gotten more common in the last 20 years...a lot of shops can balance now and there doesn't seem to be as many machine shop around either. At least around here that is what I've seen.
                  • Agree Agree x 1
                  • 33 IMP
                    33 IMP Well-Known Member
                    4,449
                    5805
                    Dec 21, 2017
                    taxifornia,soon 2b Arizona.
                    Local Time:
                    7:05 PM
                    In theory, if the new piston weight is close enough to the old pistons, a rebalance shouldn't be necessary , BUT, why take a chance on losing fillings in your teeth if it did need a balance job? In the old days, when a rebuild was under a grand, I could see skipping a step here and there. Now that a fresh 440 is around five grand, what's another couple hundred bucks?
                    When I pulled my max apart, it had some unknown brand of domed forged piston in it, with a hard chromed crank. The piston weighed over a thousand grams,WITHOUT the pins and rings. The crank had four slabs of 1/4" steel welded to the crank cheeks. My new pistons weigh 750 grams with pins.
                    I think I'll rebalance.
                    • Like Like x 2
                    • yella71
                      yella71 Well-Known Member
                      1,035
                      1468
                      Dec 18, 2018
                      nj
                      Local Time:
                      10:05 PM
                      Really? Comparing a ceiling fan to an engine? Good luck with your engine
                    • threewood
                      threewood FBBO Gold Member FBBO Gold Member
                      4,749
                      5935
                      May 30, 2014
                      Yuma, AZ
                      Local Time:
                      7:05 PM
                      I'd say that while it's apart it is cheap insurance to have it done so it doesn't cost any sleepless nights. My engine balance cost $220 a few years ago.
                    • dvw
                      5,372
                      7636
                      Feb 16, 2010
                      waterford mi
                      Local Time:
                      10:05 PM
                      Back in the day I was a dumb kid. My 1st car 68 Road Runner 4 speed. It had a transplanted 440, Cast iron 6 pac. Racing it at Milan Dragway, it lost about 15psi oil pressure. I could hear a ticking. Drove it home 45 miles. Puled the pan in my dads garage and found #5 rod spun. Crank looked fine. I pulled the head and piston/rod. Polished the crank with 400 grit. Then went to the dealer and ordered one new rod, $45 in 74. Who knew you could get used rods or have them resized? I didn't. When it showed up (10 days) it was much larger than the rest. In it went. Ran that motor for years after. Eventually I "rebuilt" it and put it in a Dart. By now I knew that it had one 6 pac rod and 7 LY rods. Swapped the one rod turned the crank, new rings, bearings, valve job.
                      Doug
                      • Like Like x 4
                      • Thanks! Thanks! x 1
                      • BSB67
                        1,486
                        1190
                        Jan 18, 2018
                        PA
                        Local Time:
                        10:05 PM
                        That's a funny story.
                        • Agree Agree x 1
                        1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                          By continuing to use this site, you are consenting to our use of cookies.
