71gtx471
Have you checked for a broadcast sheet, doubtful it survived but you never know.
I just did. I was laughing because I removed the arm rests and they had cigarette butts and a soda/beer can pull tab that must’ve been in there since the ‘70’s.Have you checked for a broadcast sheet, doubtful it survived but you never know.
100% TRUTH... Just sold an A12 Bee been im family since new. Restored once. Finally sold to AUSTRALIA for good.. Now for a DRIVER car.. Easiest $140,000 Ive made since Baghdad Mint 2005Swap on as many correct parts as you can find, gather as many better parts as you can find but avoid a complete rest unless you feel shoving needles under your fingernails is a good time...
Put a trunk floor in it, repaint the engine compartment, swap on an unmodified A12 hood.... Replace the worst parts with better parts but restoring it will not be nearly as much fun...
Trust me, I've restored enough cars, I love a fresh shiny restored car but when driving it your always stressed to a certain level..
Plus getting anyone to do work for a reasonable cost or in a reasonable length of time is about as likely as the Titanic pulling into New York next week..
It’s not, but it’s creepy it’s so close! Texas tags are different and the hood is different. And my front bumper is trashed from being towed by it. Mine doesn’t have that triangle in the grille and has a small dent in the left front fender near the headlight that’s been there since at least 1982.
Final decision made. I want to drive it, but I want a fresh start.
So, I’m stripping it down. It’s going to the sand blaster, then the restoration shop for a new trunk floor and some minor rust and dent repairs, a new rear crossmember/shock mount, and subframe connectors.
It’ll be sealed in epoxy, then repainted with BC/CC.
I plan on swapping in disc brakes in the front.
Original block and trans will be stored. For driving, it’ll get a rebuilt 440 with fuel injection and a Tremec 5 speed.
What he aught to do is take the drive to your shop & talk to a guy that knows Mopars...you're at the critical point.....but I strongly suggest consulting with the "restorer" before sending it out for any blasting........ for a few reasons
1, it's easy to destroy good, useable metal
2, much of the needed blasting is behind metal that will eventually get cut out
3, personally, I cringe whenever a car "goes to the blaster".......the "blaster" doesn't understand any of this and just wants to be paid
I prefer the "blast as you go" technique ......
if the "restorer" doesn't do his own blasting, the job suffers....... that is my opinion, but is pretty much based in fact
take a look here, it's a detailed look at what things could and should be
pay attention to my posts, the thread gets a little cluttered
just a little off the back and sides please
That would be the lower grille support, and I would imagine that any number of them can be readily found to replace that. However, I would leave that car just the way it is, do as mentioned above and out all of the missing and original parts back on it, get it running, and drive the heck out of it. You will get so much appreciation for that car in its “as found” condition. Return it to what came from the factory, but with all of the battle scars it’s wearing from a lifetime of being what it is now. My car is worse off than that one by quite a bit, but I get told all the time…”don’t ever restore this car, it’s too cool the way it is”. If I buy something for my car, I make sure it’s in line with the patina of my car. I even asked the license plate guy to send me his #2 or #3 condition plates, I didn’t want em too shiny. As for worrying about the value, I believe the value of a car is in its enjoyment that the owner receives from it. My car was made to beat the crap out of it, and that’s just what I do. How could you have that car and not want to do the same?
