383man
Did you get the tranny fixed for third gear ? Third gear is just the front and rear clutchs as no bands are on in third. How is reverse as it also used the front clutch in reverse along with the low/reverse band but at a much higher pressure so many times reverse can still work if the seals are worn in the front clutch enough that third is not working. If no reverse also then you know its the front clutch problem. Ron
