Crackedback
- 12:02 AM
- Aug 12, 2008
- Southern California
Lots of ways to skin a cat...
Those controllers are pretty cool deals.
Have you done a bulkhead wire around solution?
If you plan on running the fans primarily when the car is off, the battery is a good spot to pull power. If the idea is for them to run when the engine is running, pulling power off the alternator charge stud is the place to go. With a sufficiently sized wire around solution, either point is a decent spot to pull power. I still prefer alt charge stud.
Without a wire around, you are taxing the bulkhead with your fan amp load = BAD!
