451Mopar
Not sure if this helps, but last time I looked (several years ago), Edelbrock listed 29 different metering rods, and I had the 6 metering rods from my old Carter strip kit.
The standard jet sizes go from 0.071" to 0.116" diameter on 0.003" diameter increments.
Of the 35 different metering rods I have in my list, the upper thick section diameters (Economy) run from 0.055" to 0.076" diameter, and the lower thin sections (power) run from 0.037" to 0.060". The differences in the thick and thin sections of the rods can vary from 0.000" (no change 0.055" x 0.055", Edelbrock #1436) to 0.038" (0.075" x 0.037" which is a difference in area of almost 311% or about 7 jet sizes (calculated in area not diameter), edelbrock #1458.)
If you sort the rods by step difference, about 1/2 of the rods seem to be more for some special tuning situations with either very little change from power to economy step difference 0.000" to about 0.010"), or a very large step difference (0.026" to 0.038".)
This leaves about 12 Edelbrock rods, and the rods I had from the strip kit, that seem to have a fairly normal step size difference of 0.012 to 0.024", which is about like a jet size difference of 2.4 to 4.7 or 48.4% to 128.2% change in area.
There is also the step-up spring kit of 10-springs for five different vacuum levels ranging from 3" of vacuum to 8" of vacuum.
Accelerator pump nozzles are normally 0.024", 0.033" or 0.039", but can be re-sized with a pin drill to different sizes if needed.
There are also different diameter needle and seat assemblies 0.110", and 0.120", but normally not an issue.
My Holley tune up parts kit is even more extensive with air bleeds, metering block restrictors, power valve, jets, vacuum secondary springs, accelerator pump cams, and the discharge nozzles.
