Edelbrock Fuel Line Question?
dodge68charger
8:41 PM
Washington
Running a stock 440 with a Edelbrock Carb
Can I Run a 5/16 Line To The Carb From The 3/8 Pump?. Just Looks A Bit Cleaner
How Did You Route Your Fuel Line From The Carb To The Pump?
thanks
5/16" will support flow up to about 500hp at continuous flow. So unless you're wide open a-lot, yes, 5/16" is just fine.
