moparcrazy
Anyone got a set They would like to sell ?... Thanks !!
Cheap at summit, a little bit of work and there good to go,
you will need a few hings if your going with these ,
tin fabricated valve covers to clear rockers, a bit of clearance work to pushrod area , especially if using larger push rods,
depending on rocker ratio, you may need to shim these to get he right pattern over valve stems,
valve stem clearancing, valve lash , port matching as per usual
Why would you want them? Pain in the ***, nothing fits.
Doug
Doug
I have a set of fully CNC ported Indy EZ heads. They have titanium retainers are all fresh and ready to run. Made 773hp on my pump gas 500" motor. Pm me if interested.
