Electrical Connectors
Birdski
5:30 AM
Delaware
I have a 73 RR with the original choke control unit with 2 wires going to it. Is there a trick to getting the 2 wire connectors to "unplug" from the unit? They are loose but I can't get them to come off without breaking stuff. Thanks for your advice.
Are you talking about this? If so, use a little bit of pb blaster or other penetrating oil. Most likely the wires are corroded to the tabs on the control.
