Engine Code Question
68 RT
4:17 PM
Aliso Viejo, CA
I have a 68 Charger RT with a 70 440 engine. The fender tag decodes as a 440 HP engine. The stamp on the 70 engine is an L code or what I believe to be low compression code. There are many more markings and dates on the stamp pad, possibly by the engine rebuilder. my question is, would a comparable engine in 1970 be stamped HP and not L?
Speaking stock setup, absolutely HP (not getting into rods/crank difference etc 68 vs 70). Loaded question though as to what's been done to your current setup and how important to you a NOM should meet what it was born with.
From the odd stamping, I believe it may have been an RV or truck engine. it was rebuilt at one time, has a big cam and original 4 barrel intake. The only way to know if they built it to HP specs is to get it dyno'd. That's for another day though.
Without going to my book, L should be for "Low Compression". As far as HP goes, unless the car is a collectible numbers matching vehicle, it is basically an ego trip wanting to have the HP stamp. All it meant anyway was a hotter cam/valve spring/ex. manifold setup, and possibly different carb and distributor. There is NO physical difference between a HP and a non-HP block.
1970 440 block castings = no difference.
HP vs. "non-HP" engine = big difference in how it ticks and breathes.
I would think if they did a cam swap they would have wanted it to breathe better also. At least your NOM is in the same color range as original.
4mayhemi mentioned this... As far as I know, these are the differences between a 68 "HP" motor & a 70 "HP" motor + a little side info.
1. In general, "HP" motors got a slightly larger cam, better flowing exhaust manifolds (& maybe a different carb?). You already have a larger cam.
2. 70-73 "HP" motors will have "six pack" connecting rods (even 4 bbl. versions) and will be EXTERNALLY balanced. If you look at your harmonic balancer, externally balanced ("six pack" rod) motors will have a little "horseshoe" weight on them. They are the same thickness as a "small rod" motor (cast crank harmonic balancers are about twice as thick as the other harmonic balancers + all 70 motors should NOT have a cast crank from the factory). Non-HP 70 motors will have completely symmetrical harmonic balancers (& so will 68 "HP" OR 68 "non-HP").
3. In 68, they hadn't developed the "six pack" rods yet..... I also don't believe the 69 440 six pack motors had the bigger "six pack" rods either, fyi.
The bottom line is:
a. If your 70 motor is "HP" you can just look at the harmonic balancer
b. A non-HP 70 motor would more closely match a 68 "HP" motor (both would have forged cranks, but the smaller, non-"six pack" rods)
c. You've already changed the cam & if you've added headers too, that's 2 out of 3 "better than HP" items. Add a 750 vacuum secondary carb & you'd have "3 out of 3" better than HP.
d. The heads, block, crank, intake (all the important stuff) are identical
The bottom line is:
Thank you, great info here! I'll eventually get it dyno'd to dial it in anyway. It's a bit of a dog off the line
