Engine ID
ahmincha
7:23 PM
Cleveland Ohio
I have a engine in my garage would like a little help id ing
side of block 2532130-1
LS
under distributor V 36
6 12
Intake 2806307
Any help would be appreciated Thanks in advance
After checking 3 sites for verification I came up with this...
Block-2532130 383 B 1965
Intake 2806307 After checking I can not find a manifold listed for that number although there is a listing for 2806301 which is a later model 383 68/69 intake manifold.
One more ? what does the 4 23 64 stand for Wouldn't that be a little early for a 65
Yes because V = model year 1964. 36 = 361 CID
So a casting of 4/23/64 would be right.
6 12 would be the assembly date of June 12th (1964)
Ok gotcha but if you look up the # on the side of the motor its say 65 383 2532130
Not trying to be a pain just trying to understand thanks
Not sure what to tell you on the block casting numbers.
The V stamp indicates an engine built for a 64 model year car. If it was a 65 it would be an "A" The casting date and assembly date fit together pretty well for installation in a 64 model year.
Let's remove all doubt. Measure the bore.
Casting Number CID Year Type Remarks
2202843 170 1960-64 G
2463230 170 1965 G
2463395 170 - G
2264478 170 - G
2205630 170 - G
2463430 225 1966 RG
2806830 225 1968-70 RG Includes 198
3462605 225 1975 RG
2951694 225 - RG
2202857 225 - RG
2205528 225 - RG
2465330 273 1964-66 LA
2806030 273 1966-69 LA
2463252 273 - LA
2536130 273 1965-69 LA
2806130 273 1966-69 LA
2264230 318 1960-66 A Polysphere
2468230 318 - A Polysphere
2532630 318 - A Polysphere
2466090 318 1967-74 LA
2806030 318 1966-69 LA
2806030 318 1967-74 LA
2536030 318 1967-75 LA
2566080 318 - LA
4104230 318 - LA Race - Painted Orange
2780930 340 1968-73 LA Except T/A & AAR
3577130TA 340 - 6 bbl 1970 LA T/A & AAR
1944929 350 1958
3418496 360 1971-74 LA
3870230 360 1975-78 LA
4179930 360 1975-1993 LA
1737629 361 1961-64 B
2120329 361 1958-66 B
2120429 361 - B
2128854 361 1964 B
2205712 361 1958-66 B
1945429 361 1965 B
2658930 361 1965 B
2120229 361 - B Industrial
1852029 413 1959-62 RB Max Perf. & Truck
2120529 413 1959-65 RB
2205697 413 1959-65 RB Passenger Car
2468030 413 - RB
2658836 413 - RB Industrial
2205697 426 1964 RB Passenger Car
2406730 426 1963-65 RB Wedge & Max Perf.
1852029 426 1962-65 RB Wedge
2468030 426 - RB Wedge
2440873 426 - RB Wedge
2532230 426 1964-66 RB Wedge & Max Perf.
2658836 426 - RB Industrial
1851729 383 1959-64 B
2128854 383 1964 B
2532130 383 1965 B
2120329 383 1959-60 RB Golden Lion
2899830 383 1970 B
2568130 383 1959-71 B
2468330 426 1964-71 RB Hemi Head
2536430 440 1966-72 RB
3614230 400 1971-72 B
3698630 400 1973-78 B
4006530 400 1976-78 B
3698830 440 1973-78 RB
4006630 440 1978 RB
Its a 383 1965 B wanna sell it? let me know
Well I finally got around to tearing apart the engine. Bore measures 4.108 So i believe its a 361
Theres one, don't believe everything you read!
2532130 casting listed as a 383, but built as a 361 based on the V36 stamping and your measured bore. Mopar back then you gotta luv'm
