Factory Sway Bar
dcmason69
12:24 AM
Seward Nebraska
Does a factory sway bar from a 68 charger interchange with a 69 Coronet?
and if so does the hump go over the brace from the radiator support to K member
or under?
Saw one on 68 charger that the hump was pointed down under the brace, that cant be
correct or am i missing something?
Hope someone can weigh in on this.
dcmason69
The only thing that could be different is if the 69 Coronet did not have a factory bar then the end link tabs will be missing on the lower control arms. I believe they are available aftermarket.
OK that is what I thought,
Thank You
So say a person put a factory Sway bar on upside down what does that do to the handling of the car?
It would take less than an hour to reinstall the bar correctly. No reason not to.
