PurpleBeeper
And a little tip on the Quick Fuel plates....they come with 0.039" (or 0.037") idle fuel bleeds (which are screw in & I think are correct for the back of a 3310 750 vac. secondary carb)....anyway, 0.029" are correct for six packs & Quick Fuel sells them cheap if you call them (not listed on website). They take a 0.050" allen wrench and sometimes they're a PIA to remove/replace. On my 2 Quick Fuel plates, 3 of 4 came out easily, but for the 4th one, I had to jam a small flathead screwdriver into the allen head plug & heat the plate with a propane torch to get it out. If you order from Quick Fuel direct, maybe they can put 0.029" 's in for you at their end?
