First autocross this weekend
Rusty knuckles
1:31 AM
South dakota
Taking my 69 charger to my first ever autocross this weekend. It's more or less stock but do have front and rear sway bars. Hoping for a fun experience. Not concerned about being the fastest guy out there. Just really wanting to feel out these sway bars in a controlled environment.
Good luck. I've raced a turbo neon, about as fun as you can get.
What I learned from autocrossing. I wasn't as talented as I suspected and am actually a slow learner.
Don't be discouraged when a 1100cc POS goes faster as there is a steep learning curve. Get as many runs as you can, every time you go. After it's done, there is sometimes a chance to keep running. We pay $2 per run after the competition is over. Go straight to end of the line over and over until they tell you it's done.
Seat time is what you want, get as much as you can. Ride with experienced people if you can and watch what they do. I go faster with passengers, so weight isn't everything.
Watch other drivers and the faster cars will not look faster. Smooth is fast. Read about Apex approaches and try to be smooth in every throttle, brake, and steering change. It's fun to tear up and I cheer Vipers who smoke their tires for half the course, but they are not turning in times that are up to their potential. I think some people are there to tear up without getting a ticket, and I applaud them. It's fun to watch.
Shifting costs you one second... one second is a long time. I will sometimes stay in the lower gear rather than shift and let the rev limiter do its thing. When I enter the next corner, I don't have to shift and the motor helps slow me while I am in a good rpm range for coming out of the corner. Some come off the line smoking, I start in 2nd gear without tire spin which actually saves me one second on most courses, Again, one second is a long time.
Have fun and only compete with yourself. You will always be faster than some, slower than others. It does us no good to think of ourselves as better or worse than someone else. Practice makes improvement (no such thing as perfect) get as many runs as you can. After you have 50 runs under your belt, you will understand.
And don’t use the brakes! You’ll be much faster!
Follow me for sound auto x advice!
:D
Good luck and have fun!
I'm a loooong time autocrosser in open wheel FMod.
My advice is get to the site early and spend more time course walking than you think you need. When you can go back to your parking spot and visualize the entire course and run it in your brain then it's good. If they run "heats" and most do, pay
attention to other well driven cars, really watch what they do and don't do, a lot can be learned by others screw ups.
Some regions have newbie course walks, take part if offered. As mentioned get rides even if only allowed after your runs are done.
Biggest mistake I see with new people and big cars is they almost always are too rough with weight transfer, throttle and braking...basically asking the car to defy physics.....it don't work! Have to give big boats a chance to respond to helm inputs!
Almost forgot...Don't be a squirrel...that dumb SOB that mows down 14 cones while sideways smoking tires on every run!!
I'll admit as a corner worker once throwing and bouncing a cone off a Mustang drivers windshield.......
Thank you Sam and Dave for your inputs. Oh I certainly am not going out with a chip on my shoulder. So far I'm the only car in the pre-89 group. This is more of a test and tune day for the more frequent fliers. I'm just going for a good time. It's been a decade since I've done any racing at all. I had planned to leave it in 1st or 2nd. Just depending on course speed.
I always say it's more fun to drive the old girls than look at them in the garage.
Hope she runs/drives, like she's on rails :carrot:
I'm sure the sway bars will help
good tires & shocks also would too
good luck & have fun
that's what these cars are supposed to be all about
driving them, aggressively even,
the way a muscle cars were meant to be
Nobody will volunteer this, but an extra point for each cone hit. I means you are trying harder.
Man was that a blast! I was happy with how my car ran and drove. Now I just need more seat time. My car is very balanced or just a touch loose if coasting or at a neutral throttle. It pushes like crazy when I'm on the brakes. And of course coming out of the corners I had to manage wheel spin. But overall very happy with only having a front and rear sway bar on it. I got faster on every run and my fastest laps were the ones i barely used the brakes. Just let the engine slow me down and so was smoother in the corners. I was about 4 seconds slower than the Miata's on a 1 min course. I'm sure a good chunk of that is me being inexperienced.
Rated 10/10. Will go again
Great to hear!
There s an old original video of a 69 charger 500 being tested by motortrend I think. That's what I think of about racing these old boats. They're not bad!!
