EccentricMagpies
Is the bolt pattern on the flex plate equal? (i.e. does it matter which hole aligns with which converter mount)
One is offset slightly. I got in the habit of making a witness mark on one of the converter lugs. 360s are external balance, make sure you have the right converter.Is the bolt pattern on the flex plate equal? (i.e. does it matter which hole aligns with which converter mount)
If the bolts line up you are good to go. I they don't, then spin the converter one hole at a time until they do.
Does the torque convertor have a drain plug?
If it does it goes 180 degrees from the 3/16 hole drilled in the flex plate...View attachment 965974
