For all of You Train Lovers
That bridge can be made out of 2 inch foam, cut 4 inches and standing it on the 2 inch side. Cut out the holes and carve in the stones. Top it off with a 1/2 inch piece on top hanging over a 1/4 inch on each side and carve it also. Washed in brown acrylic and dry brushed in lighter shades of browns and tans. I have more ideas than I do space. The whole thing can get out of control. LOL. I use one of these to lay out the 4mm blocks, 7mm long.
Stewart recently moved his entire layout from NY to England.
That guy can build a nice skyscraper.
Richmond's triple railroad crossing 4th time in history 3 trains lined up TD Oct 13, 1958.
An improved scan of the vertical triple crossing of railroad tracks in Shockoe Bottom, Richmond, Virginia, including locomotives on all tracks. train trains Bob Brown 1994 (from copy negative of original print)
1994/Bob Brown
An older picture of the "Triple Crossing" in Richmond, Virginia. October 1958
Some more "Triple Crossing" pics:
Nice work guys. Ulli go over to Pacific and check out the little hobby store/ museum they used to have a lot of nice train stuff. It’s been awhile since I’ve been there but it’s worth a nice drive. It’s on the left before the tracks. Heading out of town.
Eureka has an antique shop that I go to that has a booth with a ton, I mean a ton, of old train stuff. He has more rolling stock and locomotives than I've ever seen. The problem is, I've run out of space. I've officially reached the point of having more stuff than I do space on my layout. I'll check it out, Thanks!! I found a guy that makes backdrops photos. I'm having him make me one in HO, 36" by 144".
3 unit gas turbine. Referred to as the “big blows” head end unit was powered by a small diesel engine for shunting around. The B unit was the turbine engine that made all the power, 8,500 hp. And last, the fuel tender, they burned bunker C heating oil.
Lots of power, but also lots of fuel consumption. That unit carried 2,000 gallons of fuel, plus another 24,000 gallons in the tender. UP also experimented with a turbine train that burned powdered coal instead of oil.
