Pulling off wiring and accessories. Radiator was full of mud. Started getting windy so I came inside. I need to unhook the trans lines, wiring, shift bracket, pull the drives driveshaft. Then push it in the shop and pull the motor/trans.
No updates other than I got the exhaust off and transmission drained. The weather is getting better so I will start working on it more. I still need to drop the driveshaft, roll it into the shop, and pull the motor.
Engine and transmission are out! I had a free day and decided today is the day. So I aired up the flat tire and used my little tow and push vehicle to push the truck in the garage. Wife was planting roses so I was solo.
Getting the engine out wasn't terrible, but there was some cussing. Got the engine mount bolts out, removed the trans mounts. I did find a few wires, cables and hoses still connected.
I had to modify my lift plate to fit the 2bbl tbi intake.
Pulling both trans and engine was sketchy but once I got it pulled high enough that the oil pan could slide over the radiator support I danced it out lol. I was standing on the back of the hoist and bouncing it back slowly until the tailshaft was free.
