Rjvb3
Hey everyone, I'm mocking up my front hotchkis sway bar and running into a few obstacles. For a little background, I'm running qa1 LCA's with a full Hotchkis TVS kit and stock k member on my 69 coronet. As suspected, the sway bar end links do not line up with the tabs on the QA1 lowers. The original plan was to fab a 90* bracket from the lower shock mount hole to mount the end link to.
The issue with that is the offset in the eyes on the end links are several inches apart, and the end link bushings will be seating far from square, and be only millimeters away from the strut rod. I believe this will casue rapid wear on the link bushings.
To counter this I had an idea. Thought of using 4-bar rod ends with poly bushings (https://www.speedwaymotors.com/Spee...hread-Zinc-Plated,25122.html?sku=91008001-STR) on both the LCA tab and the sway bar and running a bolt with a spacer though it, mocked up as pictured.
Again, this is only a mock up, I'm not quite dumb enough to use a pair of offset spherical rod ends to try to control tensile stress. But with a pair of rod ends with poly bushings, I would have tons of room, it would allow some flex in the bushings, and things would align great. Does anyone see any potential issues or potential to bind with this? I am by no means a suspension geometry expert.
I realize there may be other sway bar options that would fit better, but I already have this thing and would prefer to keep and use it.
Thanks!
Thanks!
