john.thompson068
I have a 20 gallon aluminum fuel cell with a sending unit. It came with some blue foam inside. I had the cell installed in 2007. The tank had a crack in the pick up area between the two fittings. The shop drained out my full tank of gas, pulled out the foam, and welded the crack. They then put the foam back in, and then poured the gas back in.
Recently after the car was sitting in storage for two years, the car has developed a fuel pressure problem, which is causing me to have carburetor issues. The fuel pressure guage wasn't reading proper pressure so I checked the fuel filter and found a piece of foam in it plus a lot of foam bits and grit. That is the top picture.
After I cleaned the filter the car immediately began to have normal fuel pressure and ran perfect, for about 1/2 a mile. Then the same problem returned. So I looked at the filter again and found more gunk. That is the second picture.
