I’m sorry, fuel what? Filter? Line? Thanks!Get rid of the a/c,lol! Try wrapping fuel in alum.foil first.
I`d take a look at the metal line coming to the pump too. But an elec. fuel pump would solve the problem.I’m sorry, fuel what? Filter? Line? Thanks!
Sorry, fuel line. Cheap try. Holley also has a carb base gskt with aluminum shield to slow down the heat.I’m sorry, fuel what? Filter? Line? Thanks!
i split a piece of 3/8 fuel line and wrapped my 5/16 line with it in the same location.Look at where the fuel line runs along the frame rail near the engine. My Dart it seems to run close to the exhaust. I put a heat sleeve on it. Seems to help.
My thought too. Plus I have 5/16 hard line from the tank to pump then 3/8 from outlet of pump to filter and 3/8 to carb. Seems like a lot of extra fuel hanging around in the 3/8 section. I’m gonna go 5/16 steel from pump to Edelbrock carb 90* hardline unit and fuel filter. Should be 1/2 the length I have now and much less 3/8 section. May have to insulate the hard lines though. We’ll see.Wonder if those long fuel lines are making it worse? Exposing fuel to engine heat longer?
I'd do both. MO on rubber hose is less is better.Guys, if the fuel is boiling out of the carb nothing you do to the fuel lines will fix it, only reducing the transfer of heat to the carb will fix it. Common things to do is add an insulator under the carb, block off the heat cross over in the manifold (pretty sure the RPM doesn't have one), buy a carb more suited for it, run non ethanol fuel and install an electric fuel pump. Although the electric fuel pump does nothing to actually fix it it does give you the abiliy to turn the key to on long enough to refill the bowl prior to starting. I had these problems, 1/2" phenolic spacer and a new Quickfuel (special coating) carb fixed it.
If your referring to insulating fuel lines and carb when you say "Both" I 100% agree. I was only pointing out that the lines have nothing to do with fuel boiling out of the carb. You still will boil fuel in the lines but instead of not starting it will stumble shortly after starting, usually within a mile. I still have this trouble occasionally (usually when I get crappy fuel) but it's very minimal and I insulated the fuel line beside the header. I honestly believe the best fix for this is a return style regulator with a return line to tank, add electric fuel pump and I'm pretty certain most line issues would disapper. I've been wanting to do this for years but $$$ just hasn't been there.I'd do both. MO on rubber hose is less is better.
I have that option in my back pocket. Not currently in the mood for new sending unit and more fuel line, but you’re right it’s the “nuclear option”. This is my last attempt at the cheap fix. If I go pump and return, would probably go EFI carb too.If your referring to insulating fuel lines and carb when you say "Both" I 100% agree. I was only pointing out that the lines have nothing to do with fuel boiling out of the carb. You still will boil fuel in the lines but instead of not starting it will stumble shortly after starting, usually within a mile. I still have this trouble occasionally (usually when I get crappy fuel) but it's very minimal and I insulated the fuel line beside the header. I honestly believe the best fix for this is a return style regulator with a return line to tank, add electric fuel pump and I'm pretty certain most line issues would disapper. I've been wanting to do this for years but $$$ just hasn't been there.
With the electric pump and return regulator you fix 2 things at once, fuel never sits idle in one spot and it allows you to reroute the line where it's not passing past the header or exhaust.
I “had” vapor lock problems a few months ago because my fuel hoses were laying on the manifoldSonny, do you have problems driving the car, does it want to stall out? If fuel is boiling in the gas line that is called vapor lock. But if you only have problems starting the car after shutting it off you are boiling the gas out of the carb from heat. Before changing your fuel lines I would try the Edelbrock Heat Insulator Gasket 9266 (it is only $20) on your RPM air gap intake, you will be surprised how good this gasket works. Edelbrock made this gasket just to stop fuel percolation, they know what they are doing.
I removed the heat riser and any internal valves.yes you will want a steel line from your pump to your filter and then to the carb and using only a short piece of rubber gas line at the fuel filter for the connection. We have never had a problem with gas percolation after installing Eddys 9266 or 9265 Nitrile rubber composite gasket and that's on 440 motors to. Like oldbee said is you exhaust heat riser stuck closed it should be open after the motor warms up?
