toearley
Running new hard fuel line from mechanical pump to carb on 1971 Charger with 440. Two questions: 1.) What is the correct path to run the line? In "front" of and "around" the distributor, or "behind" the distributor and "over" the valve cover? I've seen it pictured both ways. Also what is the consensus on fuel filter placement? On the carb side or on the tank side of the pump? Thanks for helping the rookie again.
