ram250098
So here is where I am at. New sender new voltage limiter new fuel tank.
Now I used some jumpers and hooked the new sender up to the wire from the tank and the fuel gauge operates as it should. Put sender in new tank and hooked up my meter set to 200ohms and moved the float up and down with a stick and it reads correct.
Took meter set to 12volts and checked blue wire I am getting power 0 to 6 volts...I know it works as I checked with the fuel sender out of the tank and the gauge worked.
Install tank in car hooked everything up and even put on a few extra grounds with some jumpers one to the sender itself to ground and another from the tank to the body..both tested good grounds.
Turn on the key and nothing the gauge only moves a hair...and I mean a hair!
This is the same problem before all the new stuff..what am I missing here.
AL
AL
