I put a new TanksInc tank in my Charger a few years ago. This tank has an in-tank electric pump so there are two openings at top of tank. I noticed leaks almost immediately. Leaking at fuel sending unit and fuel pump opening. Sending unit and fuel pump installed per TankInc instructions. I used the seals that came with the tank. Well I finally removed the tank to facilitate other maintenance. I removed sending unit and pump. Both gaskets look perfect and tank mount surface looks perfect. I did not use any RTV or other sealer on initial install. My thoughts are to use some black RTV however, this should not be required for a leak free seal. Has anyone run into this problem with this type of seal? If so how did you fix it. Thanks
Frank
Frank
