Street fighter
I have a 73 charger that is in need of the gas gauge repaired or replace. I have replaced the tank sending unit twice so I don't think it's the sender. the hand was going to full if you added 5 gallons to the tank. Now the hand sits in the empty location and jumps back and forward. I don't know much about the gauges, but I have made sure that the sending unit is well grounded and there is voltage going to the sending unit. I'm thinking about sending the dash gauge section to have it tested and repaired if they need it,I only use the gas gauge because I have aftermarket water, oil,and voltage gauges. have anyone had this happen and if so how did you fix it?
