2059
- 11:58 AM
- May 4, 2012
- North Central Indiana
OK Gents, here ya go. My gas gage worked intermediately in the beginning and now it will pull off the "rest" position and go to empty and that's where it stays. Here is the trouble shoot list so far, all continuity tests:
1) Confirmed good ground from the sending unit body to car body not just the tank.
2) Confirmed continuity from the sending unit probe to ground. 75 ohms. (depends on how much is in the tank, my guess 3/4 to less than full. Topped it off ~40ish miles ago)
3) Confirmed continuity from the sending unit wire to the rear half block harness connection behind the drivers kick panel. 75 ohms.
4) Confirmed continuity from rear half harness block to dash harness block. Full continuity.
5) Confirmed continuity from harness side block to lugs at gas gauge in board. 75 ohms on one stud and full continuity on the other.
6) Confirmed continuity between the studs on the gauge. Don't remember the resistance but it was not an open circuit.
What the hell am I missing?!?! Don't want to just start changing parts.
Thanks in advance!!!
BTW: Have a great Labor Day Weekend!!!!
