Green Bearing Question
dart4forte
3:38 AM
Mesa, AZ
I’m currently running green bearings on a 8.75 rear.The other day I noticed a little splash of gear oil on the inside of the driver side tire. Haven’t pulled the axle yet so my question is can the bearing be cleaned with solvent and if so can it be re-packed? I’m thinking the rubber o-ring is leaking. Anyone know the size of the o-trying?
As far as I know they are a sealed bearing.
They're sealed. It's far more likely the axel seal (behind the bearing) is leaking.
For all of the warnings about the catastrophic failures that will occur with these things, I have yet to see any on my cars.
Now, I only had them put on a set of axles because it was done before I learned of the potential for failure BUT they haven't failed yet. I've put 3000+ miles of road trips on a set with no problems but when they start to go bad, I will return to the stock Tapered Timken design.
Same here, been using them for years. However, those people that are road racing or auto crossing it’s recommended not to use them. Has something to do with the lateral stress on the bearing.
So if the bearing is sealed there’s no chance of the bearing being washed out with gear oil?
Unlikely, unless the bearing has failed and the seal is broken. However, there are only a few ball bearings in that bearing, so when the seal fails - which is part of how the balls stay in place - the bearing gets pretty loud. In other words, when green bearings fail (in my experience) they fail fast. I put green bearings in all my cars, so I'm not downing on them.
One more thing... there is the seal and then there is the o-ring, which is just to catch the little that might slip past the axel seal.
That’s what I thought
The only reason I have ever used green bearings is on a 4 wheel disk application. Tapered bearings on rear wheel disk applications sometimes causes some rear brake noise because of the very slight movement of the rear axles.
The whole bearing and axle is held in by that snap ring on the green bearing?
Some don't put in the inner seal when switching to green bearings, relying on the tiny o-ring.
No idea if the o-ring is reliable or not, but I put some grease on them and always install a new inner seal for some insurance.
Yep. The plate that is slid onto the axel prior to pressing the bearing and lock ring onto the axel catches the snap ring on the bearing resulting in holding it to the housing so the axel doesn't come out. The bearing rides inside of the housing-end, held in by the plate pressing against the snap ring. The o-ring on the rear side of the bearing is close to the actual axel seal. And, of course, the axel seal is pressed into the housing, which is your primary seal. If you have signs of gear oil on the back of the tire/wheel or brakes, it's almost certainly the axel seal and the o-ring has failed too, or just can't keep up with the flow. I think the o-ring on the bearing is really just a "helper".
Yeah... I've been told that as well. But I don't trust the o-ring. And there's nothing stopping using the axel seal and the o-ring on the green bearing... so why not have both :)
Anyone happen to have the part number for the inner seal?
Don't forget there's a different gasket to make up for the thickness of the lock ring.
It's not the same as the white foam gasket.
