Gtx rear seat surround mockup
Gus chiggins
8:09 AM
None
Mocked up the rear seat surround in my 67 plymouth belvedere 2. I had to do some tweaking ( nothing major) to make it fit. Yes, it's a four door. I just have to get the hooks.
I would have thought the hooks would be universally mounted for the seat back in all body styles. Do you remove the sedan ones?
Yes, I had to remove the two hooks for the sedan. They interfered with the seat surround. I believe the hooks are the same. The GTX hooks are probably the same as the belvedere, but they are inverted. I had to do a little tweaking to the surround but, nothing major. I will have to look for the lower mounting braces for the lower part of the upper rear seat. The hooks came off easy. I took pliers and moved them back, and forth, and they broke off clean. I will remove the surround, and shoot it with SEM trim black. It was not difficult to pull this off.
The GTX / Satellite takes completely different mounting brackets for the seat back than Belvederes. Here is a photo of a 1967.
1966 brackets are narrower, and so are the holes on the plastic seat surround. Yet another part that is different 66 to 67.
1967 Satellite also
Yes, i forgot. I actually saw a c body with a similar surround on ebay. He was selling the seat back, and showed a picture of the car. I tried to convince him to sell me the hooks, but he insisted that those hooks would not fit a b body, the hooks looked the same to me. I did not argue
Could you show me the lower seat mounts for the rear upper seat for a 67 GTX, 66, 67 Satellite?
True, but some used the sedan hooks but inverted them to secure the seat back
Sprayed the seat surround today. Sprayed a prep solvent then painted it SEM trim black. It's boring waiting for IAN.
If i do another one of these seat conversions, stephens performance sent me the seat mounting brackets, and the seat hooks. I now have an extra set of hooks, and i removed them from the panel using a spot weld cutter. I trimmed up some of the panel remnants, now i have perfect templates to cut the holes for the hooks next time i do this. Plus i have the floor shift template too, no guess work figuring where the console brackets go.
