Hi guys,
I have a 68 charger project. I am trying to figure out the proper method of getting it in nice keepable shape.
The first thing was/is this car was a rust bucket. So a lot of the sheetmetal will and is new. New rear 1/4s new decklid filler panel. New trunk floor. New Floor inside. (leaving the floor by the base of the rear seat and the front area that meets the firewall. And leaving the hump.
A lot of the new repro panels come primed. So what I am trying to figure out is at the priming painting stages what would be my best bet. Since there will be a lot of new metal and some old. Does it pay to get the entire car media blasted? Just my bad areas that I uncover blasted? Is there a type of sanding that wont do longterm damage? (I read sand blasting causes tining and metal deteroration). Is a chemichal soloution better?
If I am leaving or using the repro panels and not blasting them do I only etch prime what is blasted or sanded down to bare metal? Or skip and goto an epoxy primer?
Does any filler (which I plan to be minimal) go before the epoxy primer? Or can it go to the filler primer?
How do I treat restoring different areas? Like would you just por15 your rear axle? Try and blast it then epoxy?
Same with interior floor pans / trunk area?
Any tips I am doing a lot of reading and seeing a lot of conflicting information.
Thanks....
Thanks....
