Ok so how does the 6 clips go in for the trim piece? Do I cut the headliner were they go or just push them in? Will they be some what loose or tight? Thanks for any help,this weekend project.
Wayne so I do the hole first?Push'm in the hole and GENTLEY squeeze the tabs to spread the rear wings. Use a soldering iron to start the hole...
Please learn from my mistakes.Dave, I'm glad you're ahead me in the process. I'm watching your progress & questions.
That’s a great ideaThose clips look like the ones on my 65 Belvedere. I modified the clips and installed nut serts and 10-32 screws to retain them.
Mike
I do the exact same thing.I wish I never would have taken those stupid brackets off...no matter what I tried I couldn't get them to relock back in with any confidence. Didn't want to chance them falling out later, once the windshield is in, you're blocked out.
I ended up running a screw in to hold them good.
The square holes get one of those clips like you have in the installed in the round hole in the pic. There are six clips for mounting that molding. That's how it is in my 70 GTX.Good morning, I have installed the front headliner cap mounts (with a screw to make sure they stay). I do have a question though, What are the square holes on the furthest outside end of the windshield?
Also, for a '69 Charger do these clips look correct? They do seem different from photos above. I'm not sure if they are just a different looking bracket but ultimately work...just not sure.
Good lordy mercy....did the factory run out of drill bits and have to go to a punch? One of life's mysteries I guess ;)The square holes get one of those clips like you have in the installed in the round hole in the pic. There are six clips for mounting that molding. That's how it is in my 70 GTX.
Whatever is the cheapest and fastest to get the job done!Good lordy mercy....did the factory run out of drill bits and have to go to a punch? One of life's mysteries I guess ;)
Thanks for the info!
