Who makes a hei male distributor cap for a stock electronic distributor Big Block? Part numbers would help and a photo if you have one. Thanks
What does any cap look like?You can run any cap unless you need the “coil in cap””. Not sure what your looking for.
I think he was asking about the male ends on the cap like the Magnum small blocks use.
i think he wants you to look up part number and give it to him . you know how hard it to find that info.If he said what he was doing the forum could be more helpful I suppose
I am asking if anyone has put a hei cap on a stock bb distributor. The one with the male hei terminals. If they did where did you get the cap. I found one from Summit! just want to now if there are other choices.i think he wants you to look up part number and give it to him . you know how hard it to find that info.
If so easy YOU look it up and tell us what you find.i think he wants you to look up part number and give it to him . you know how hard it to find that info.
Thank you for the reply. This was the only one that I found also. Have order my stuff today from SummitView attachment 807284
Notes:These are replacements for Summit distributors with part numbers: SUM-850027, 850028, 850080-1, 850082-1, 850420 and 850421. These will also fit OEM Mopar V8 distributors, SUM-850003, 850003-1, 850004, 850004-1, 850005 and 850005-1 distributors, converting to a male/HEI style terminal.
look at post #4 then look on a parts store web siteI am asking if anyone has put a hei cap on a stock bb distributor. The one with the male hei terminals. If they did where did you get the cap. I found one from Summit! just want to now if there are other choices.
dont need to i run M. S. DIf so easy YOU look it up and tell us what you find.
