Hello FBBO and friends. 74 sebring
74moparguy
7:18 AM
Tulare, Ca.
trying to figure out why my tire is wearing out on the inside. im not sure what it is called but i adjusted it so the tire will lean more to the outside but its still not helping. could to be the ball joints wearing out.
also for the canister for the fuel how to remove it or what do i do with the fuel line the runs to it.
Castor... toe .....camber Sound like you have to much toe in......... Take a look at these links they are helpful......
Caster is the fore or aft slope of the steering axis. The steering axis is a line drawn through the upper and lower ball joints of the knuckle. Positive caster is when the bottom of the steering axis line is in front of the tire's contact patch. Zero caster is when the steering axis is at 0 degrees. Factory alignment specs for basically all vehicles call for a certain degree of positive (shown) caster. This ensures good stability, helps maintain straight-ahead direction and promotes steering wheel self-centering.
Toe is the side-to-side difference in distance between the front and rear of the front tires. If the distance is closer at the front, it's called toe-in. If the difference is closer at the rear, it's called toe-out.
Camber is the inward or outward tilt of the front tires as viewed from the front. Inward tilt is negative, outward tilt is positive. Camber is used to distribute load across the entire tread. Improper camber makes the tire wear on one edge, and causes the vehicle to pull to the side that has the most positive camber.
http://www.allpar.com/history/mopar/front-end-alignment.html
http://www.camplulu.com/tractor/Manuals/Alignment/SnapOnAlignment.pdf
http://vintage.mitchell1.com/PClubData/chassis/dch76/V2D769005.pdf
ok thanks, but could it be worn out ball joints. ill look in to that tomorrow
