rumblefish360
A stack of camshafts for a $100?
Do you know there specs?
There’s a couple crane fireballs, MoPar purple shaft cams in a few different sizes, a comp cams mechanical roller with something like 880 lift. Guy was cleaning out his shop. They all have the cam cards with them. To answer a couple of your guy’s questions I would like to make around 550 horsepower, the car will be driven on the highway but likely not very far, there are only small highways around me and the maximum speed is around 60 mph. Currently the car runs mid 12s and I have a whole stack of time slips, one of which reads 9.8 so maybe the previous owner was running nitrous? It’s had about 30 passes on it in the last few years or so. I already have plans to drive a different car to work or school so practicality is of little concern I just want something that makes a good amount of power nothing crazy and makes lots of noise. By what I’m hearing sounds like a single plane will be better than a dual plane. Is it possible to make above 500 horsepower with the stock iron cylinder heads? I have the choice of 906 or 915
Build a motor that's going to last you more than 10 years. It can be done using a roller cam . Aluminum heads is the best way to go for a projected build of over 500 hp. There's people out there that drive high horsepower cars that are durable enough to drive almost every day. It just comes down to how much you're realistically wanting to spend.
.....I would like to make around 550 horsepower,
Is it possible to make above 500 horsepower with the stock iron cylinder heads? I have the choice of 906 or 915 castings.
