74Sebring
Hi all, I sure hope someone can help me solve this mess. I have a 74 Sebring Plus with a 360 4BBL and 727 Trans. The carb is a Carter Thermoquad 6545s. The car idles way too fast and everything i try to correct the problem just makes the idle faster. Tomorrow, my cousin and I are going to rebuild the carb. I really want this TQ to work. I'm a fan of the TQ and hate the idea of an Eddy or a Holley taking its place. I know this carb will perform. Ok, what's been done so far. 1. Ignition timing set to 5 degrees before TDC, 2. All vacuum ports on the carb and intake are either connected to a device or capped off. 3. throttle cable has been lubricated and checked for kinks. 4. idle and mixture screws have been set to a beginning base point (mixture screws gently bottomed out and turned back 1 1/2 turns, fast idle screw gently in contact with the second cam notch, curb idle screw just in contact with cam), 5. there is no electronic solenoid on this carb but there is a vacuum device where that solenoid would be. it seems to do nothing. 6. the vacuum pot for the choke appears to do nothing as well. the vacuum advance on the distributor works perfectly. 7. an entire can of carb cleaner has been run thru already. 8. there are no discernible air leaks (but the car is pretty loud so i'm not positive). I could understand if the idle would hold high but, everything I've done that, according to popular convention, should slow the idle has only increased it. I seriously believe I could drive down an interstate highway without ever using the gas pedal. Any ideas, including chicken sacrifices and voodoo rituals, will be gratefully appreciated. Pics of my car will be posted soon. I've just been losing my mind trying to fix the idle.
Thanks, 74Sebring.
Martin :cussing:
Thanks, 74Sebring.
Martin :cussing:
