Skytrooper
1SG (Ret.)
"Overhead Door" has the North East sewn up....
Overhead Door Company is who I worked for ! A franchise based out of Lewiston, PA (I worked in Rochester, NY)
After you replace the broken spring, make sure that your cables are properly set in the drums before winding the springs. A lot of the time, a cable will "jump" the drum, or come unwound when a spring breaks.
With both springs broken (according to OP) there will not be any tension on the cable and will most likely just be dangling at this point
I got my start in the Ironworkers Union with a company called New Jersey Door Works. We did commercial and industrial rolling steel and sectional doors, as well as loading dock equipment. Overhead Door is mostly residential in N.J., though they do some small commercial.Overhead Door Company is who I worked for ! A franchise based out of Lewiston, PA (I worked in Rochester, NY)
If cables are loose, winding them is simple. Set the cables on the drums and wind the shaft counter clockwise until both cables are tight. DON'T loosen the drums, it's not necessary. Once the cables are tight, lock a vice grip on the shaft and against the wall on the top of the shaft. that will keep tension on the cables as you wind the springs. Don't release the vise grip until you wind both springs and tighten the set screws. A 3/8 8 point "star" socket works great to tighten the set screws.
I don't have too much experience with residential, but that makes sense with a single hollow shaft. All of the doors that I did during my 16 years in the Ironworkers had either a split shaft, or in some big industrial cases, four shafts and as many as 8 springs. Most of my experience was with rolling steel and dock levelers.You can get away with that on split shafts. If it is on a 1 inch hollow tube, then you have to take them off to slide the springs off. we all learn different ways. I do 14 years experience making a living on garage doors. Star socket is awesome !
OP, Good Luck with the repair ! There is a lot of good advice from people who have tackled this job before.
We're mostly big block people over here.I actually have the manual to the door that says "9.6 turns". Really?? How do you do 0.6 turns?
Odd that everybody over at FABO says don't do it I will die, and everyone over here is encouraging me to tackle the job?
It's not that difficult to replace those springs. Do you have enough room to slide the springs off the shaft to the side? If you don't, it's best to remove the shafts and assemble them on the ground. Then carry them up and reinstall. Start by unbolting the center coupler that bolts the 2 shafts together. Then, remove the bearing plates from the end of the shaft where it meets the tracks. Carefully remove the cable from the drum and lay it over the top roller. That would be a good time to inspect the cables for fraying and/or damage. Lay the shaft on top of the track and move to the spring hanger plate. While holding the shaft, unbolt the plate from the wall. A cordless impact is best so that you're not ratcheting the lag bolts forever. Carefully lower the shaft to the ground. Repeat process on the other side. Once on the ground, remove the drums by loosening the set screws and removing the key stock. Don't lose the key, it's important. Slide the drum off the shaft. The drums are side specific, so don't mix them up.Split shaft. Picture below when spring 1 broke. The third service guy tried to clamp the spring and the left spring broke as he was working on it.
View attachment 1089219 View attachment 1089220
That door is heavy, he's going to need some help.Pull the release and lift the door.
Thar she blows!The door should balance halfway in the opening.
Unbolt old springs from the hanger plates. Install new springs, which are also side specific. Bolt the hanger plates on the new springs. Slide the drum on with key, but leave it loose. Carry them up and slide the drum end over the track. Bolt the hanger plate to the wall with the lag bolts. Slide the end bearing plate onto the shaft and bolt it back to the track and wall if it has a wall mount. Repeat on the other side. Now you're ready to start the winding process.
You will need a minimum of 3 vice grips to safely wind the springs.
Clamp 1 vice grip on each side above a roller to keep the door from lifting off the ground during winding.
Slide the shafts toward the center but don't bolt the coupler together. Insert the cable into the slot at the back of the drum. Slide the up against the bearing plate and, with the key installed, tighten the set screws. Wind the cable onto the drum by spinning the shaft until the cable is tight. Make sure that the cable is in the proper grooves on the drum. The cable should come off the back of the drum. While holding tension on the shaft, clamp a vice grip to the shaft and against the wall to keep tension on the cable. You don't want any slack on the cable. Now you are ready to start winding. Use a bright spray paint of welding chalk to draw a straight line long ways across the front of the spring, from hub to hub. Using winding bars, start winding the spring clockwise. Position your ladder so the your winding arm is in front of the winding hub, but your face is out of harms way. As you wind, the line you drew will spiral and multiply. Every line on the spring is 1 turn. If it calls for 9.5, I would go 10 turns on each spring because the spring is going to give as it breaks in. Once you have the desired amount of turns, tighten the set screws on the spring hub. Since you have a split shaft with a keyway, tighten one set screw into the keyway. Don't overtighten of you will break the set screw. Once the screws are tight, you can remove the vice grip from the shaft.
Repeat this process on the other side. After both springs are wound up, then you bolt the center coupler together.
Carefully remove the vice grips from the rollers. Keep your foot on the step plate of the door in case it wants to go up. Check the spring tension with the opener unhooked. The door should balance halfway in the opening.
