- 11:48 AM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
I have a 4781-3 850 dp. It's was run a little bit by a previous owner, and a little bit by me. The problem is, I need to look inside, clean it out, etc. to make it usable.
The problem is.... it was put together by Holley with the non non-stick gaskets, and it might as well be welded together. I can get the choke parts (plastic) off, and some accel pump linkages (also plastic) but the base, bowls, metering blocks and accelerator pumps are NOT coming apart.
I MIGHT be able to pry the base off, but there is NO place to pry on the bowls or metering plates.
Any good solutions out there? Chemicals to try? I don't really wanna dip the whole carb intact, and I'm not sure the currently available dip would get the job done anyway. Help?
