How do you i d the year of a 727 trans
Look thru the hole and see if u just see metal or plastic. Plastic is the 3 pin. Metal is the single pin. Ofcource it depends on the year of your vehical. 68 and back is single pin. 69 up is 3 pin. U may have to mix and match cause the valve body may be a different year also. Kim
Great info. I'll take a look tomorrow. Thanks for your help.
So I took a look and this is what I see ... I am guessing by the color this is plastic so I need the three pin switch?
If you have the pan off, there will be a casting date on the valve body, on the area over the accumulator piston. It will tell you approximate year.
