How low can you go?
306Doba
5:38 PM
Saskatoon, SK/Victoria, B.C
Looking to lower my car a bit in the near future, nothing major just 1 or 2 inches and was curious if anyone knows how low you can lower a Cordoba before running into issues with front tires rubbing when cornering.
Thanks for any info
It kind of depends on a few things like tire width and diameter, and wheel offset. Mines' pretty low and I've never had a problem w rubbing. That's with a 245/60 15" tire on a 15x7 rim. It used to sit lower but I raised it back up an inch or so, not because anything rubbed, but because A) you lose some of the effectivness of your torsion bars when you take tension out of em. And B) unlike the older cars our later B bodies don't have an eccentric in the upper control arm to push the top of the tire out resulting in excessive camber. It not only looks goofy, its bad for your tires too.
It's not the definitive answer you're looking for, but I can put a tape measure to my 76 and tell you where it sits now if that'll help. It's probably 2" or so lower than stock, ballpark.
To paraphrase Nike....Just DROP it! An inch won't hurt nuthin', that's about 8 turns of the adjuster bolt, by the way. Also, if you let it down a little at a time, til you find the height you like, that's way easier than going too far and having to crank it back up....ask me how I know THAT.
I get more compliments on the stance of my car than any other single characteristic. Then again, that's kind of a skewed statistic cuz everything else on the car sucks. :headbang: HA!
sorry, man. i don't do lol.
hey thanks for your input, I remember seeing a couple pictures of your car and really liked the stance. Did you do anything for the rear? how does she handle in the corners? endless amount of twisty back roads around here and my only other concern would be unpredictable steering when cornering at higher speeds (not something I do on a regular basis but it is fun pushing a tank to its limits through the curves. I'm surprised at how well it handles in stock form)
Also after I lower it I was planning on re aligning it back to spec
The back is lowered too. It handles fine, but not great. I attribute that to the 37 yr old bushings, ball joints, etc. The front suspension is in need of a complete rebuild. Even stock rubber replacement parts would make a HUGE difference.
