JG1966
When I do the 12 o'clock/6 o'clock test on my right front tire (car jacked up, suspension unloaded), I'm getting a little wiggle. Maybe an 1/8 inch in and out (it's really hard to tell). When I use a big crow bar under the tire, I am getting less movement, but still a little bit. I know there is an acceptable vertical tolerance from the FSM of 0.070 inch, but I don't have the dial indicator tool. Is any noticeable movement too much? Both ball joints (and virtually everything in the front suspension) are relatively new (four years, probably 2,000 miles). What else can cause 12 to 6 movement? Thanks
