JedIEG
I am having a hard time getting my 318 to run right and pulled the pcv valve off the carb to eliminate as many vacuum leaks as possible. When running without the valve, I am seeing a decent amount of blow-by puffing out of the breather tube. I don't see any signs of oil consumption on the plugs (just a lot of dry carbon from the rich carb). Rings are original with 84k miles.
Should I worry about this? How much blow-by should I be seeing?
I'll try to take a video of what I'm seeing tomorrow.
