Kevin74
Hello,
I’m new to the hobby and still have a lot to learn. My thanks in advance for all the expert advice. Here is my story:
I bought a 67 Charger with no engine or trans. I then found a great $2500 Craigslist deal on a barely used 505 and 727 trans. Also a set of Doug’s headers. Here are the engine specs from the previous owner:
440 stroked to 505
10.5 compression
Ported 905 heads
1.5 roller rockers
Comp cams XR292R solid roller
Anyhow, I installed the engine and I don’t like it. Just way too much cam, I think. Idles very rough, and I had to add a vacuum pump for my power brakes.
So here is my plan:
Swap cam to Comp cams XR272R
Install thick 0.080 to 0.100 Cometic's head gasket to lower compression to 9.0 to 9.5. I’m thinking the smaller can won’t tolerate 10.5:1 on 91 octane.
1. Do you guys like this plan? I’m not a racer. Mostly just want to cruise around in an old muscle car.
2. Anything to be concerned about with the super thick head gasket? Does it make my pushrods too short?
3. Can I reuse my lifters?
Thanks!
440 stroked to 505
10.5 compression
Ported 905 heads
1.5 roller rockers
So here is my plan:
Thanks!
