Hub centric rings
moparcanuck
Deceased, But not forgotton
Legendary Member (RIP)
11:08 AM
Ottawa,Ontario
Anyone using these with Cragar SS mags? I have a vibration between 60-70 and am pretty sure one rear tire is off centre. I've had the wheels balanced several times and the vibration is still there. I've had the wheels and tires checked to make sure they're true.
Unless your using some sort of uni-lug rim,most of these aftermarket rims are lugcentric. There are rings and spacers available to get back to hubcentric again.
I donot like unilug wheels but did you check brake drum and axle
Check run out on the car and mark with chalk the high spots the rotate and check again
Good luck
