Aron Gleason
So I've been looking at the comp cams 251/257@.050 564/564 lift with 110 lsa. To replace the mp 284 484 cam. What's everyone's thoughts? Would it be a nice rowdy lope?
I was told I should be able to put that cam in place of my 284 484 without issues?Well it's one big hydraulic. About 10 or more degrees bigger than the 284.
Would be pretty surprised if it didn't have some snap crackle pop.
You would agree about???I’d agree
Who said that. The guy that previously built your engine and knows all the clearances?I was told I should be able to put that cam in place of my 284 484 without issues?
No to being a bolt in in a stock engine.
I never said it was a stock motor.
Sounds like it's not stocknon stock motor. It's far from a stock motor.
. Not that it changes a damn thing.Thank you for the informationJ-convertor and 4.57's should work just fine with a big stick like that.
Good information. That's what the machinist told me 30 years ago when the motor was built.That lift is a little tall for comfort with stock height valve guides.
Is 10.5 a measured value or a I bought these 10.5 pistons value? A measured value with no valve reliefs I would be checking valve to piston clearance for sure. If the pistons have valve reliefs it should be ok, but checking would not hurt, peace of mind and all.
Good advice. I have heard of the 128 rule. I'll have to watch that video.Try educating yourself on cam selection so that you can make an educated choice, not relying on 'Bill's cam picks'.
The correct LSA for a 440 cam with 906 heads is 104; not 110. Derived by using the 128 rule.
128 rule?
The best explanation of 128 is one I saw recently on a YT video. It was by Cattle Dog Garage & goes for 34 min [ sorry, I do not know how to link ]. That 34 min video will give you more cam knowledge than you have ever had. There is also a a longer 1hr + video, but the 34 min video is all you need. It confirms D. Vizard's 128 rule with PROVEN dyno tests comparisons.
You will not be able to get a 104 LSA cam for a 440, so you will need to compromise. 108 or 106.
I would use a single pattern cam such as the Isky 304 Mega [ 108 LSA ]. A much nicer street cam with better manners would be the 292 Mega. If you can find a grind from Hughes or Howards on 106, that would be better. DV has a good saying: the right cam cost the same as the wrong cam. Have your old lifters re-faced if do not want lobe/lifter failure.
