Ironbuilt
- 12:54 AM
- Jul 1, 2017
- North Carolina
Now I know what you need for Christmas:
Thanks Bio, then my truck can look like this...
Boy you can say that again. VERY NICEThis truck is a BEAST!!!
Just emptied my inbox.your mail box is full tried to send a message to you
I took my first load from Petersburg, Va. to Fargo, ND. Then reloaded in Milbank, SD. for Elberton, Ga. She didn't pass a truck stop that she didn't want to stop and get fuel at.(Yes, almost 2 MPG difference so far. I think that I have to learn to be a little lighter on the right foot.)
If your driving long haul that will add up in a hurry.
They seem to think that the problem is a pinhole in the wiring...SOMEWHERE!!
How the pinhole got there, I have no idea, if that was even the cause of the issues. I kept getting Engine Fault codes and every time I brought it in to the dealer, the codes were coming up as "Communication failures". Meaning that the DPF sensors were sending codes to the ECM that were not able to be read. They changed the sensors twice, re-flashed the ECM and spent countless hours trying to get an active code so that they could try and repair it. No luck, and I tried 3 different dealers. The down time was killing me and my wallet. It was all covered under warranty, but the warranty doesn't pay the bills. So I contacted Paccar, the parent company of Peterbilt and Kenworth, and started the negotiating process. Thankfully, they did the right thing.So tell me. How do you get a pinhole in some wiring and how would that cause the problems you had??
I see the pin head!!
Might have been a Lucas wiring loom (Prince of Darkness) and all the smoke escaped from the wires. There is a kit that can cure that problem, without having to get a new truck....So tell me. How do you get a pinhole in some wiring and how would that cause the problems you had??
KW is a Paccar too.I told you Paccars are problematic!
What's the KW got under the hood?
