I have a Disk brake conversion question
Encswsm
6:52 PM
Mobile Alabama
Bought a Disk brake conversion kit from Dr. Diff. the kit is awesome and nicely organized. I have a question about the master cylinder and distribution block.
The outlet hole on the Master cylinder and the distro block inlet for the Front (Disk) brake side is bigger than the one for the back brakes. Do I need to run a larger diameter brake line or can I use the 3/16th line like everywhere else.
Line size should all be 3/16. There are some variants in tube nut sizes.
Thanks fellas. I kinda thought that as I got the proper sized tubing nipples to fit the larger holes along with the tubing I bought online.. Right now I have the whole front suspension blown apart. Ill let yaall know how the Brake change goes.
