monaco66coupe
good luck with it! that VIN should be there on both eng and trans. if not,,,,,,,plus look at the part number on the transmission. the early GTX had 2801541, until after 5 May SPD, then the number should be PK2892093.if the 10,000 day code is after the 2801541, it will probably be Dec like the original engine. if the other transmission number is there, that will likely tell you the transmission is the original, and what real date everything was put together. Plus, if you see a whole other Part number on that transmission, then get back to the guys here.
Aren't old cars fun?
