D575
- 5:59 AM
- Feb 22, 2012
- High Desert, Northern Nevada.
I need help. this is what I have, car had a small vac. leak at the manifold
so I changed the pan and sealed it up real good, at the same time I blocked off the heat riser. it's a six pack car . it runs like a raped ape. except when I do a long downshift to a stop. then the idle goes away and wants to die. a quick blip of the gas and it's idling again. any ideas ? float level is good . mixture is good, great color on the plugs. would too low a power valve cause this ? when I had it apart I checked the power valve and it was good. I had 8 inches of vacuum . now it's 11. I believe it's a 4.5 PV I'm going crazy trying to figure this out..
