Road Grabber
- 3:43 AM
- Apr 14, 2020
- Sarasota Florida/NY State
Did plug the power booster line? If you have a bad unit it will cause a vacuum leak.
It’s not a good idea to have those ignition wires wrapped around each other.
Check your firing order? Watch the engine run in the dark and see if you have any spark jumping anywhere.
Do the plugs have oil on them? If the intake is leaking underneath it’s likely you won’t see anything cause the fluid runs down. A leaking intake will touch on top runners but not seal underneath if the gasket thickness is not matched properly
Switching out a distributor would rule that out. A cough up the carb is typically a lean condition or intake valve open during ignition.
Are these hydraulic lifters?
If it’s not a carb situation then ignition or still a leak you haven’t traced down.
I have also had a warped intake one time that drove me crazy.
I’d start with cutting and separating the ignition wires properly. If not now it will cause issues in the future.
