Ignition issue with my 72 charger?
carsonp
4:04 AM
Minnesota
i was backing my 72 out of my garage and it died. I wasnt sure if it was just cause it wasnt warm at all and i put it in gear to fast or waht, but when i went to restart it nothign happened. wont even try to turn.
Now, the blinkers still work in acces. but nothing past that. Any ideas?
Start with the basics, since it won't even turn over, I'd check battery connections, wires to the starter, can you jump the starter, check for voltage at the positive side of the coil, neutral safety switch as mentioned, get your tester out, start checking who's getting and not getting voltage. Since it won't even turn over after it died, it may be something in the ignition switch, but check fuses as well, hope for something simple.
