TS5064
INDY MAXX ALUMINUM BLOCK
this block is new, never used. it will make up to a 645ci. i bought it to build a 645 ci predator motor. i bought a complete motor so i don't need it. here are the options this block was ordered with.
raised cam option
4.500 Bore
48*deg lifter bore
lifter bores moved out .125"
10.720 deck height
5" stroke clearance
55mm cam bearings {loose not installed} the block is ready for the bearings to be installed
drilled for push rod oiling
std. oil pan bolt pattern
$5000.00 OBO plus the ride. or message me here or call me at
712-309-xxxx thanks wes
raised cam option
4.500 Bore
48*deg lifter bore
10.720 deck height
5" stroke clearance
