Interesting 727 info - exploding transmissions - John Cope
icetech
5:56 PM
Detroit
Great video, I have never had a 727 die luckily, but i have never made over 500hp prolly either :)
440 PHIXX
The Island of Misfit Mopars
4:56 PM
Lansdale Pa.
I’ve heard they blow up after doing a burnout because something welds itself together. I’ve never rebuilt a TF, but I’m going to learn because the one in my daily is giving up the ghost.
icetech
5:56 PM
Detroit
They are pretty easy to build.. get that book that is out that is step by step.. i will need to build one also once i figure out what engine i am doing.. this is going to take forever at this rate :)
dvw
5:56 PM
waterford mi
It's a informative video. Billet drum is the single best thing you can do. If you run a stock drum low band apply would be #1 on my list. I have and still do run the chettah style no low band apply valve body. Never an issue. My racecar has a billet drum, aluminum shield, 16 element sprag. The 65 green Plymouth pictured in the video is a friends nephews car. Nasty explosion. Even the converter came out of the car. Common sense in 1st gear is #1. However that won't protect you from a failed drivetrain. I've never failed a sprag myself. But it does occur. That being said a stock valve body applies the low/rev band in manual low.
Doug
Dodge 330
4:56 PM
Wichita, KS
Lots of misinformation out there spread by people who have no idea what they are talking about! Everyone will tell you that you need a billet drum and bolt in sprag and that is absolutely not true!
Dave6T4
5:56 PM
Ontario, Canada
I knew most of this stuff, but John did a very good job of demonstrating just how a Torqueflight works. Plus sharing his experience of his trans explosion. This is likely what lead him into the high performance transmission business. Thanks John.
440 PHIXX
4:56 PM
Lansdale Pa.
Might have been E-Berg. Something about coming out of the burnout box onto dry asphalt. And the drum or something welding itself.
Cheapsunglasses
4:56 PM
Texas
Eh, it’s not that difficult, I build one on the tailgate of a pickup at midnight with a flashlight, and extremely basic tools. Worked fine afterwords.
